Maui Forums › Maui Support › Plasma Desktop › Virtual keyboard just before login after reboot
Kurtbw Offline
3rd April 2018, 7:03
Not sure if this was a bug or what.  So I thought I'd post here.
As the title indicates, what I see just before the login screen is the virtual keyboard.  In British English, no less, even though I use no other keyboard setup besides US English.
Maui recovers gracefully when I hit the button for the real keyboard.  It's a minor annoyance.
KDE Plasma 5.12.3
KDE Apps 17.12.2
Frameworks 5.43
QT version 5.10
3rd April 2018, 10:01
Yes it's a bug of some sorts. Others reported that aswell. Though it only seems to happen in certain scenarios.
kaktux Offline
4th April 2018, 12:53
(3rd April 2018, 10:01)leszek Wrote: Yes it's a bug of some sorts. Others reported that aswell. Though it only seems to happen in certain scenarios.
i got that to - but after wondering some seconds i just typed in my login password, hit enter and it worked - so i dont bothered any further.
If we can help with need some information to find that (small) bug - just say so. If not - nevermind Wink
hiryu Offline
Tongue  19th April 2018, 20:29
I checked these forums a few months ago to see if anyone had the same issue... I didn't find anything. Now I randomly hop on the forum to see if there's any release schedule about an upcoming Maui release now that Ubuntu 18.04 is around the corner, and see this. Tongue
Anyway, I get this same issue too. I have it on my laptop, my desktop, and the family computer. Previously, typing my password on the physical keyboard wouldn't work, I'd have to use the virtual onscreen keyboard. However, it seems typing on the physical keyboard may work now, but I haven't tested it much.
I haven't tested it much, because there's a little keyboard looking button on the bottom right hand corner of the screen that you can press to make the virtual keyboard go away so you can type in your password as normal.
This isn't remotely persistent as the next time you try to login, the issue will be back and you'll need to click on that button again, but it is nice to be able to get the virtual keyboard out of the way at least.
MoonRise Offline
20th April 2018, 1:28 (This post was last modified: 20th April 2018, 1:35 by MoonRise.)
This was taken from another site I'm a part of.  This worked for me at preventing that virtual keyboard.
In /etc/sddm.conf you can add, under [General], the part indicated by the "--> " before it.  Of course do not have that on the newly added line.  Couldn't figure out how to highlight that piece within the "CODE" bubble.
[Autologin]
Relogin=true
Session=
User=
[General]
HaltCommand=
RebootCommand=
--> InputMethod=
[Theme]
Current=Angelfurry
CursorTheme=breeze_cursors
[Users]
MaximumUid=65000
MinimumUid=500
MoonRise
[Image: attachment.php?attachmentid=7550&d=1526779259]
20th April 2018, 9:38
Ah nice. Thanks for this followup.
hiryu Offline
20th April 2018, 17:11
Yeah, that did it for me. Good find.
My /etc/sddm.conf didn't have a [General] section, so I added your example in its entirety.
If you don't mind my asking, what other site is this with this sacred SDDM knowledge?
MoonRise Offline
21st April 2018, 15:57
https://www.kubuntuforums.net
MoonRise
  Slow to load desktop from login screen atowler 24 104,271 1st December 2017, 13:42
  Some Desktop Effects Stop Working After Reboot sputnik_tr_02 2 14,382 28th April 2017, 9:36
Last Post: sputnik_tr_02
  BUG: Flash of desktop before screen unlock on return from Suspend nilzon 5 24,577 11th April 2017, 16:46
Current time: 17th April 2026, 1:20 Powered By MyBB, © 2002-2026 MyBB Group.
