Maui Forums › Maui Support › Software & Applications › Qtransmission can't set to spanish
21st October 2016, 18:39
When I installed Maui, I need to install kde-l10n-es for full translation to spanish.
Whit, others applications (like firefox, thunderbird, libreoffice...) I need install her languages packages for spanish translation.
But with qtransmission, I can't or view some package for translate to spanish.
Its possible I need install this packages?:
language-pack-es
language-pack-es-base
language-pack-gnome-es
language-pack-gnome-es-base
Regards.
21st October 2016, 20:55
Yes you can install those aswell. Iam not sure however if qtransmission has a Spanish translation. Normally it should provide this with its default package.
21st October 2016, 21:26
Ok, I try to install those aswell and post the result.
In my last distro (Linux mint) I was use transmission (not qtransmission) and are in spanish.
Now, I view in synaptic transmission (not qtransmission) and I try to install transmission, but have a error, unsatisfied dependencies, and can't install.
Regards!
22nd October 2016, 11:14
I installed this packages:
language-pack-es
But qtransmission continue in english.
I don't know if I need install language-pack-kde-es package (I view its a older package).
The strange is this, qtransmission works, but if I uninstall qtransmission and want install transmission, I can't (algo for synaptic or Discover), I have a error with unsatisfied dependencies.
But are the same application (qtransmission and transmission) in my older distro, I was use a transmission, I was made a backup of config folder of transmission, and now, in Maui I restore this folder and all my settings are the same.
Regards.
Current time: 1st July 2026, 21:17 Powered By MyBB, © 2002-2026 MyBB Group.
