Maui Forums › Maui Support › Software & Applications › [Solved] Okular 1.0.0 has major issue with PDF files
monteleo Offline
13th January 2017, 15:28 (This post was last modified: 16th March 2017, 13:28 by monteleo.)
After updating to KDE Applications 16.12 in Maui 2.1, okular has a major problem with pdf files.
The problem is that many pages of whatever pdf file I open with okular are not correctly visualized. In attachment there is a pdf file and a screenshoot to show the problem I have.
Has some of you the same problem? How to fix it?
Thanks for helping.
.pdf   PDF-sample.pdf (Size: 98.9 KB / Downloads: 1,976)
13th January 2017, 15:53 (This post was last modified: 13th January 2017, 15:54 by kdemeoz. Edit Reason: PS )
Can't help you with Okular sorry (i dislike it]. Instead i use Master PDF Editor; https://code-industry.net/free-pdf-editor/
PS - I run it in FireJail, isolated from the net, for safety/privacy.
monteleo Offline
13th January 2017, 17:29
(13th January 2017, 15:53)kdemeoz Wrote: Can't help you with Okular sorry (i dislike it]. Instead i use Master PDF Editor; https://code-industry.net/free-pdf-editor/
Master PDF looks a good alternative, I'll try it.
Thank you.
13th January 2017, 17:31
I can't reproduce the issue here with Okular 1.0.0 from KDE Applications 16.12 with PDF Backend 0.65
I fear it could be a visual glitch caused by the graphics driver. Try switching off the desktop effects (Alt+Shift+F12 to toggle effects on/off) and see if it helps.
monteleo Offline
13th January 2017, 17:35
(13th January 2017, 17:31)leszek Wrote: I can't reproduce the issue here with Okular 1.0.0 from KDE Applications 16.12 with PDF Backend 0.65
No change by switching off desktop effects....
13th January 2017, 17:39
Try reinstalling
monteleo Offline
13th January 2017, 17:49
No change by reinstalling okular, the issue persists..
13th January 2017, 18:07
Which graphicscard do you have ? Did you install any special driver for your card ?
monteleo Offline
13th January 2017, 18:22
(13th January 2017, 18:07)leszek Wrote: Which graphicscard do you have ? Did you install any special driver for your card ?
I have a GeForce GTX 750 Ti with NVIDIA Driver Version 367.57 (recommended drivers) in a dual monitor.
13th January 2017, 18:58
Can you for testing purposes switch to the free software (nouveau) driver again and see if it fixes the issue.
  Maui 17.06: Firefox crashes when trying to upload files to certain pages benit 6 26,825 5th January 2018, 1:25
Last Post: rocky7x
  Okular epub rocky7x 1 9,792 14th October 2017, 13:03
Last Post: chatan
  Major difficulty setting up Kwallet summer 5 22,723 4th August 2017, 4:59
Last Post: summer
Current time: 5th September 2026, 15:08 Powered By MyBB, © 2002-2026 MyBB Group.
