Maui Forums › Maui Support › Installation › [Solved] Error in installation
10th February 2017, 19:34 (This post was last modified: 11th February 2017, 11:58 by wonder.)
I go to made a fresh install of Maui2.
In the start of installation, after partition my hard disk, I have this error:
[Image: thump_9688419maui.jpg]
I don't use a cdrom, I use a usb pen.
I try with differents usb's, have the same problem.
Some days ago, a friend, indicate to me that have the same problem.
If my friend select automatic partition, install without problems.
I don't select automatic partition, I partition manually.
Regards.
Edit: I create partitions in ext4.
11th February 2017, 0:40 (This post was last modified: 11th February 2017, 0:41 by leszek.)
The problem seems to be that it isn't finding the source for copying which is the filesystem.squashfs containing the live system.
Can you check if the sha256sum of the ISO matches the one we provide on our download page.
I have a feeling that it might be broken.
If it isn't then please tell me how you created the live usb stick.
11th February 2017, 2:09
Hello.
The sha256sum of the ISO its correct.
I view my problem.
I create my live usb stick with Multibootusb and with this are my problem.
I create again my live usb stick with SUSE Studio Imagewritter of my Maui, and now, I can install Maui 2.1 in my laptop without problems, installation fine.
Regards.
11th February 2017, 10:26
Nice. Can you mark this thread as solved by editing your initial post and add [solved] in front of it.
  Boot error - Windows interferes with disk mounting benit 1 11,112 27th March 2018, 9:47
  [solved] Installation failed RaimundD 9 44,602 4th August 2017, 16:08
  Error messages during boot Sigurd 4 22,215 1st August 2017, 12:36
Last Post: Sigurd
Current time: 11th July 2026, 7:13 Powered By MyBB, © 2002-2026 MyBB Group.
