Maui Forums › Maui Support › Plasma Desktop › Notification box
Notification box
11th July 2017, 10:45
Hello.
Since upgrade to Maui 17.06 the notification box in some times appears bottom right (like before upgrade) and other times appear in up to the left. Its possible fixed?
Regards!
11th July 2017, 12:21
Never noticed that. Sounds like an issue with plasma desktop then.
Usually it should appear at the bottom right all the time.
Can you try changing the configuration for notifications so that you set the custom position to be bottom right and see if it fixes it.
11th July 2017, 12:31
Yes, its strange becuuse, the notifications of KDE Connect all appears at the bottom right, some notifications of Chromium (only some, not all) appears or in bottom right or up left...
I go to try changing the configuration notifications for custom position and try.
Regards.
11th July 2017, 12:38
Chromium uses its own notification system isn't it?
17th August 2017, 2:14
Hello.
Sorry for delay in reply, but  I wait to reply for my fresh install.
Well, some days ago, I made a fresh install in my tower, t his problem, continue.
The notification box, in some times, appears in left side, like this 2 examples:
[Image: Screenshot_20170803_080847.png]
[Image: Screenshot_20170803_082513.png]
Like I indicate, this is with fresh install ( I backup my configs folders for thunderbird and chromium).
Regards.
17th August 2017, 9:41
That looks broken.
Have you tried settoing the custom position for notifications already?
17th August 2017, 10:15
Yes, its like broken, but I indicate above, I don't edit any, its a fresh instal...
No, I don't tried to setting the custom position for notifications, I don't know how setting custom position...
And when appears in left side, are position random...
17th August 2017, 10:35
It turns out this is a known issue see this bug report here: https://bugs.kde.org/show_bug.cgi?id=377970 (In the comments it is mentioned that it appears also on X11)
You can try still changing the position by left clicking the little arrow up icon in the panel right clicking notifications and then notification settings. Maybe this works better for you.
17th August 2017, 12:14
This had already been fixed, there is a patch for it, please read here: https://forums.mauilinux.org/showthread.php?tid=24543
17th August 2017, 14:15
(17th August 2017, 10:35)leszek Wrote: It turns out this is a known issue see this bug report here: https://bugs.kde.org/show_bug.cgi?id=377970 (In the comments it is mentioned that it appears also on X11)
Ok, I view that, its a bug, thanks.
Quote:You can try still changing the position by left clicking the little arrow up icon in the panel right clicking notifications and then notification settings. Maybe this works better for you.
Sorry, I don't understand very well.
You indicate, when appears de notification box, clicking the little arrow up icon in the panel right, click in notification box and then in settings?
If its yes, I don't view how set for box notification are only in right corner.
But like indicate above, I don't understand very well.
rocky7x Wrote:This had already been fixed, there is a patch for it, please read here: https://forums.mauilinux.org/showthread.php?tid=24543
Ok, but I view that, are a patch in the future in backports neon.
  Plasma notification history? benit 3 16,211 6th August 2017, 10:12
Last Post: rocky7x
Current time: 25th March 2026, 15:00 Powered By MyBB, © 2002-2026 MyBB Group.
