Maui Forums › Maui Support › Software & Applications › Doubt with Discover (software manger) in Maui 2
31st October 2016, 1:16 (This post was last modified: 3rd November 2016, 16:50 by wonder.)
Hi.
Only a little doubt, in Maui 1, have a Discover for search applications, but in fresh install of Maui 2 not have Discover, but the computers that upgrade from Maui 1 to Maui 2 have Discover, and if execute sudo apt autoremove, Discover software manager not remove.
Thanks.
3rd November 2016, 16:49
Hi (again Smile)
Maui 2, not have any Software Manager? (not including synaptic).
Only a doubt, in my case, I install all by terminal or synaptic, but its a doubt because maui1 have discover, computer that upgrade from maui1 to maui2 maintains discover software manager, but a fresh install of maui2, not have.
3rd November 2016, 17:58 (This post was last modified: 3rd November 2016, 17:59 by leszek.)
We never shipped discover by default. Not in Maui 1 or Maui 2.
So not sure how you end up having it on Maui 1.
For managing Software packages we only ship synaptic in Maui 2.
We are constantly evaluating Plasma Discover for future inclusion however.
Chelle Offline
3rd November 2016, 18:35
I didn't have Discover to start with (Maui 1), but it appeared after some update or other. I assumed it came with the upgrade to Maui 2.
3rd November 2016, 18:56
I was made 3 installations of Maui1 in 3 computers, and in all, have a Discover software manager, but I don't know if are after a some updates or in the moment of fresh install.
I know that, I don't install Discover, but if are install in some update....this I don't know.
4th November 2016, 3:53
I do have Discover, but only because i specifically manually installed it weeks ago, via Synaptic. Similarly i also have Muon. Nonetheless, i tend to mostly just use Synaptic.
4th November 2016, 4:03 (This post was last modified: 4th November 2016, 4:12 by AJSlye.)
I just checked my Maui 1 installed system and indeed Discover has been installed during one of the updates through Mint Update.
This leads to the question, what package is bieng updated that now has discover as one of it's dependancies?
Note: I only use this system for tech support reasons and other than running the updates, this system is a default install with no manually added software.
  Qt software and icons Bergoglio 4 19,544 15th March 2018, 15:50
Last Post: Bergoglio
Rainbow [Solved] Maui Linux Software Sources for Vivaldi. kdemeoz 2 14,788 1st October 2016, 6:09
Current time: 5th September 2026, 14:17 Powered By MyBB, © 2002-2026 MyBB Group.
