Maui Forums › Maui Support › Installation › Hello problem upgrade.
Pages ({1}): « Previous 1 2
7th January 2017, 15:48
In systemsettings there should be localization settings for changing the systemlanguage. Under Input devices you can set the correct keyboard layout.
vassi Offline
7th January 2017, 16:04
(7th January 2017, 15:48)leszek Wrote: In systemsettings there should be localization settings for changing the systemlanguage. Under Input devices you can set the correct keyboard layout.
Hello,
No, Full screen is Greek, first must change this, how?
7th January 2017, 16:13
Execute kcmshell5 translations to go directly into the localization settings.
vassi Offline
7th January 2017, 16:36
(7th January 2017, 16:13)leszek Wrote: Execute kcmshell5 translations to go directly into the localization settings.
Thanks a lot, now all is ok...
  hello, in USB 64Gb I try from Windows 8.1 64bit to create in persistent mode... but vassi 6 31,359 4th February 2018, 13:00
Last Post: vassi
  [Solved] Problem with apt-get upgrade and kde-style-qtcurve-qt5? Pfiff 9 41,470 12th February 2017, 21:44
Last Post: Pfiff
Photo hello, how install Greek characters and how to switch Greek-English? vassi 13 61,848 14th January 2017, 15:29
Current time: 13th November 2026, 5:15 Powered By MyBB, © 2002-2026 MyBB Group.
