Maui Forums › Maui Support › Installation › [Solved]: Kinfocenter - 17.03 -->About System
TomFo Offline
14th March 2017, 17:15 (This post was last modified: 15th March 2017, 22:26 by TomFo.)
Hi all,
Just upgraded to 17.03 and it's looking good so far. Thank you to all involved in making it happen.
One minor quibble I've noticed so far is The "About System" option in Kinfocenter returns an error message. Calling it from the command prompt reveals it's looking for "kcm_about_extended" but fails to find it. Please see attachments.
Any help in rectifying appreciated!
--Tom
Bergoglio Offline
14th March 2017, 17:20
Same problem for me.
14th March 2017, 17:22
Same problem
minidiegi Offline
14th March 2017, 19:29
Here it works fine.
14th March 2017, 19:48
Make sure that the package kcm-about-extended is installed.
Bergoglio Offline
14th March 2017, 20:17
kcm-about-extended is not installed.
It depends from libkwinglutils9 but I have libkwinglutils10 installed......
14th March 2017, 20:30
Then you try installing the wrong version. Make sure maui-xenial-backports and maui-xenial-backports-neon repos are activated.
Bergoglio Offline
14th March 2017, 20:34
These repos are active (not the source code)
chipola Offline
14th March 2017, 20:36 (This post was last modified: 14th March 2017, 20:37 by chipola.)
I think the correct backports are activated.
14th March 2017, 20:41
Then please take a look at the kcm-about-extended package. You need version 0+p9+git20170201.0509-0 which should come from maui-xenial-backports
Current time: 17th August 2026, 18:23 Powered By MyBB, © 2002-2026 MyBB Group.
