Maui Forums › Maui Support › Plasma Desktop › Windows decoration lost after update
chipola Offline
14th March 2017, 19:50
I updated to new maui version (17.03) and everything was smooth but now doesn't appear the windows decoration (minimize, maximize buttons) and when I Do left click doesn't appear the emergent menu.
Any comment or help will be thankfully.
14th March 2017, 19:54
Can you take a look if kwin_x11 process is running.
This one is reponsible for window management.
Do you remember if the update manager wanted to remove something kwin related ?
chipola Offline
14th March 2017, 20:09
kwin: /usr/lib/x86_64-linux-gnu/libxkbcommon.so.0: version `V_0.7.0' not found (required by /usr/lib/x86_64-linux-gnu/libkwin.so.5)
14th March 2017, 20:13 (This post was last modified: 14th March 2017, 20:13 by leszek.)
Very strange. What libxkbcommon0 do you have installed ?
Have you tried
sudo apt-get update && sudo apt-get install -f
with maui-xenial-backports && maui-xenial-backports-neon repos activated ?
chipola Offline
14th March 2017, 20:16 (This post was last modified: 14th March 2017, 20:17 by chipola.)
The following packages were automatically installed and are no longer required:
fcitx-libs-qt5 fonts-stix java-wrappers
libapache-pom-java libbcmail-java libbcpkix-java
libbcprov-java libcauchy0.0v5 libcommons-codec-java
libcommons-httpclient-java libcommons-logging-java
libcommons-parent-java libdom4j-java libetonyek-0.1-1
libglew1.13 libgnuinet-java libgnumail-java libitext-java
libjaxen-java libjdom1-java libjgoodies-common-java
libjgoodies-looks-java libkabc4 libkcalcore4 libkchart2
libkldap4 libkresources4 liblog4j1.2-java libm2mml0.0v5
libodfgen-0.1-1 libphonon4qt5experimental4 libplot2c2
libpstoedit0c2a librevenge-0.0-0 libsoprano4 libspnav0
libwpd-0.10-10 libwpg-0.3-3 libwps-0.4-4 libxerces2-java
libxml-commons-external-java
libxml-commons-resolver1.1-java libxom-java libxpp2-java
libxpp3-java linux-headers-4.4.0-57
linux-headers-4.4.0-57-generic linux-headers-4.4.0-59
linux-headers-4.4.0-59-generic linux-headers-4.4.0-62
linux-headers-4.4.0-62-generic
linux-image-4.4.0-57-generic linux-image-4.4.0-59-generic
linux-image-4.4.0-62-generic
linux-image-extra-4.4.0-57-generic
linux-image-extra-4.4.0-59-generic
linux-image-extra-4.4.0-62-generic lp-solve pstoedit
soprano-daemon
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded
maui-xenial-backports && maui-xenial-backports-neon are activated
chipola Offline
14th March 2017, 20:26
Fixed, I updated the libxkbcommon0 library. For any strange reason the system doesn't updated correctly.
Thank you leszek.
  No suspend option after recent KDE update DenisBY 6 27,190 26th February 2018, 11:59
Last Post: DenisBY
  [Solved] Lost DE after Intel microcode update TomFo 1 10,167 12th January 2018, 14:43
Last Post: TomFo
  HELP! WIFI connection lost after standby mode benit 5 23,857 4th August 2017, 17:14
Last Post: benit
Current time: 5th September 2026, 21:44 Powered By MyBB, © 2002-2026 MyBB Group.
