Maui Forums › Maui Support › Software & Applications › Auto spell / Kwrite - Kate
Pages ({1}): « Previous 1 2
RealPTR Offline
10th June 2017, 16:47
(2nd June 2017, 16:01)Raydog Wrote: In the Menubar: Settings>Configure Kate>Editing>Spellcheck and tick the box Automatic spell checking by default
If you want to toggle Spellchecking on and off you can use the shortcut Control+Shift+O.
Hope this helps. Smile
 Doesn't work....  :-(
Raydog Offline
12th June 2017, 22:36
Strange, works here. I'm using DeJavu Sans Mono fonts in Kate and System Settings if that matters.
ceres Offline
Just Stranded
13th November 2017, 2:02
I have the same problem. I changed the font, then it worked for a while. Now it doesn't. The menu has it checked, saying it should be working.
I've toggled auto spell-check, changed the font, and re-started Kate several times. Nothing seems to work.
Auto spell-check should work in any font. Is anybody here as frustrated as I am?
RealPTR Offline
29th November 2017, 19:40
In my case, it turned out to be a problem with the screen scaling. I have a high DPI screen and I've used 1.5 scaling factor for the screen. It messed up the underlining of the misspelt words.
I've reported it here:   https://bugs.kde.org/show_bug.cgi?id=383922
Current time: 20th October 2026, 19:19 Powered By MyBB, © 2002-2026 MyBB Group.
