Maui Forums › Maui Support › Plasma Desktop › Network folder
Pages ({1}): 1 2 3 Next »
Network folder
12th December 2017, 20:57
Hello.
We have a network folder in user folder.
In this folder, we have "Add Network Drive".
Well, I click, add my network drive, its my router, with this url:
smb://192.168.0.1/folder1
The first time I add, appears and works fine, appears in left panel of dolphin.
But when restart computer, dissapears.
I access to network folder, and then, click in new folder create to my router, but empty screen.
Can help me?
Regards!
12th December 2017, 23:26
Do you have any error message in ~/.xsession-errors ?
Is there any error message when running samba-mounter from the terminal?
13th December 2017, 1:51
Sorry, I don't know how view this...
(12th December 2017, 23:26)leszek Wrote: Do you have any error message in ~/.xsession-errors ?
I don't know how view ~/.xsession-errors and also, samba-mounter in terminal appears the order was not found.
Regards.
13th December 2017, 2:19 (This post was last modified: 13th December 2017, 2:20 by leszek.)
The ~/.xsession-errors file is a normal txt log file. You can view it with a simple text editor. It lists all errors reported by graphical applications that aren't shown as an error dialog or even for crashed applications.
I suggest opening that file and having a look if you find samba, samba-mounter or cifs references that might helping resolve this issue.
As for samba-mounter that is the application name of the application to mount smb network shares linked in the network folder on the desktop. The command itself might be called differently (I don't know it from the top of my head)
13th December 2017, 2:29
(13th December 2017, 2:19)leszek Wrote: The ~/.xsession-errors file is a normal txt log file. You can view it with a simple text editor. It lists all errors reported by graphical applications that aren't shown as an error dialog or even for crashed applications.
Ok. But I don't view or localice ~/.xsession-errors file...
Quote:As for samba-mounter that is the application name of the application to mount smb network shares linked in the network folder on the desktop. The command itself might be called differently (I don't know it from the top of my head)
Ok, but also, I don't know what command I need execute in terminal for view if have some error (sorry if I not explained well).
If execute in terminal "samba-mounter" appear that I indicate in my last reply.
Thank you!
13th December 2017, 10:46
The ~/.xsession-errors file is a hidden file (every file with a dot at the beginning is hidden by default)
You can make it visible by showing hidden files in the file manager dolphin (It has a button for this in the toolbar)
~ is a character that is used to represent the current home folder of your user (e.g. /home/wonder)
13th December 2017, 14:00 (This post was last modified: 13th December 2017, 14:00 by wonder.)
(13th December 2017, 10:46)leszek Wrote: The ~/.xsession-errors file is a hidden file (every file with a dot at the beginning is hidden by default)
Yes, I know that, all files or folders with . are hidden.
I have configured my dolphin for view hidden files/folders Smile
Quote:~ is a character that is used to represent the current home folder of your user (e.g. /home/wonder)
Thanks for help, ~ is a character that is used to represent the current home folder of your user, I don't know/remember this, thanks Smile
Ok, I open this file and search by "samba"
This files I view with "samba":
ksmserver: Starting autostart service  "/etc/xdg/autostart/sambamounter.desktop"
ksmserver: autostart service ("/usr/bin/samba-onstart") finished with exit code  0
The 2 lines above, are repeat some times.
fullSambaUrl "smb://192.168.0.1/folder1" sambaDir: "/folder1"
Mounting samba:  "smb://192.168.0.1/folder1-/home/ariadna/Network/TP-Link"
error while executing "Couldn't find action 'org.kde.sambamounter.mount'"
inotify_add_watch("/run/samba/ncalrpc/np") failed: "Permission denied"
kf5.kio.core: "No se ha podido entrar en la carpeta /run/samba/ncalrpc/np."
kf5.kio.core: "El archivo o carpeta samba/ldb no existe."
Thanks!
13th December 2017, 14:07
Can you try reinstalling samba-mounter please.
Quote:error while executing "Couldn't find action 'org.kde.sambamounter.mount'"
looks like some dbus service stuff is missing.
13th December 2017, 14:35
Ok but, its possible solved this?
This error its "big" for me, I don't know how solved this...
Thanks!!
13th December 2017, 14:47
Have you tried reinstalling it already?
  Can't place folder icons on desktop where I want benit 1 10,138 10th September 2017, 10:43
Question Maui 2.1 System Settings/Network Drives - Adding Shares. TonyLudwick 7 32,784 19th July 2017, 10:10
Last Post: kaktux
Rainbow [Solved] - Weird Temporary Network Failure. kdemeoz 5 23,456 30th April 2017, 4:29
Current time: 14th August 2026, 16:38 Powered By MyBB, © 2002-2026 MyBB Group.
