Maui Forums › Maui Support › Plasma Desktop › Apps icons on the panel won't get bigger
Pages ({1}): 1 2 3 Next »
evb0110 Offline
6th January 2018, 11:20 (This post was last modified: 6th January 2018, 11:21 by evb0110.)
Unlike with other distributions using KDE Plasma 5 (e.g. Kubuntu and Linux Mint 18), when I increase the height of the panel, the apps icons (which I put there using "Add to panel (Widget)") remain the same size. Is it possible to make them become larger?
Another problem is that very often, when I want to change something on the panel, it crashes and appears again only in several seconds.
6th January 2018, 16:56
Which version do you use of Plasmashell ?
It seems to me the Icons are added as widgets. They should have the same height when you pin them in the taskbar.
The first thing was fixed in a recent Plasma version.
evb0110 Offline
6th January 2018, 19:02 (This post was last modified: 6th January 2018, 19:02 by evb0110.)
(6th January 2018, 16:56)leszek Wrote: Which version do you use of Plasmashell ?
leszek, Thanks! I have 5.10.2 Plasma. So, what should I do to be able to change their size?
6th January 2018, 19:11
You need to upgrade the plasma version.
This means you need to activate maui-backports and maui-backports-neon for this to upgrade.
See the homepage about part rolling site if you need more details.
evb0110 Offline
6th January 2018, 19:50 (This post was last modified: 6th January 2018, 20:03 by evb0110.)
leszek Now, after I enabled backports and installed 5.11-th Plasma, everything is much worse. After reboot I don't have any panel at all. My laptop is attached to an external display, its own lid being always closed. So, to get the panel back, I have to open the lid, activate the laptop's screen in settings and then deactivate it. But after reboot the problem returns! Is it possible to solve this problem? Now, the system has become unusable.
And, by the way, icons on the panel don't get any bigger. Sad
UPD: Had to restore my system to the previous state. Now at least, I can use it.
7th January 2018, 20:14
That is strange. The icons should be fixed with the newer plasma versions. At least I cannot reproduce it here. As for the display issues with closed lid. This is a special corner case which seems to be a an issue with kscreen and Xorg.
evb0110 Offline
7th January 2018, 20:32
Maybe the problem with icons remained, because it was an upgrade, not a fresh install?
When I returned to Plasma 5.10, there is no 'corner issue'. Does that mean, that there will be no way for me to upgrade to 5.11?
7th January 2018, 20:44
For the icons issue it could be that the old configuration might have some hardcoded sizes in it.
As for the 'corner case' you have to test out newer Plasma versions. As boot or launching of Plasma changed through the newer versions it might be a bug that needs fixing. But as I am not using this kind of setup it is hard to tell. Maybe you can find an open bug about this on bugs.kde.org to see if it is reported already.
Also keep in mind testing with a clean config might help here aswell.
evb0110 Offline
7th January 2018, 21:02 (This post was last modified: 7th January 2018, 21:08 by evb0110.)
It seems, these bugs are well known.
https://bugs.kde.org/show_bug.cgi?id=356225
https://bugs.kde.org/show_bug.cgi?id=356727
So, I'have to stick to 5.10 Sad
Cleaning configs is a bad choice for me...
8th January 2018, 15:23
I see the same issue, but I've been seeing it even before Plasma 5.11. The icons that I've added to the panel only as shortcuts resize correctly. But the apps that I've pinned to the taskbar as launchers don't resize at all.
Cheers..
  Empty list of apps Pfiff 13 53,322 2nd October 2018, 18:34
Last Post: Pfiff
  Icons in GTK apps on buttons missing rocky7x 6 28,191 28th November 2017, 16:47
  Can't place folder icons on desktop where I want benit 1 9,747 10th September 2017, 10:43
Current time: 11th May 2026, 9:05 Powered By MyBB, © 2002-2026 MyBB Group.
