Maui Forums › Maui Support › Plasma Desktop › Plasma 5.8 Clock font small and panel resize broken
atowler Offline
5th October 2016, 15:56
After the upgrade my clock font is very small and clicking and dragging on the height adjustment button for the panel no longer works. I tried it in an effort to get my font for the clock to resize.
5th October 2016, 17:19 (This post was last modified: 5th October 2016, 17:19 by leszek.)
Just to be sure general panel resizing does not work anymore ?
If yes, do you have widgets locked maybe on the desktop ?
atowler Offline
5th October 2016, 17:35
(5th October 2016, 17:19)leszek Wrote: Just to be sure general panel resizing does not work anymore ?
Correct, I'm unable to resize the panel. I've double checked that widgets are not locked. To be sure, I locked then unlocked the widgets and it still doesn't work.
5th October 2016, 17:44
Can you try adding a second panel and see if it works there.
If it works there. Try removing the old one.
atowler Offline
5th October 2016, 18:36
I tried adding a new panel and it won't resize either.
5th October 2016, 18:48
And the clock is broken on the new panel aswell ? Can you make screenshots please.
Last resort would be testing with a new user and see if it works there. If it doesn't then you need to check if really all packages were updated successfully.
atowler Offline
5th October 2016, 20:54 (This post was last modified: 5th October 2016, 20:56 by atowler.)
The clock works but the font is now quite small. I was trying to adjust the panel height so that the font would automatically upscale itself. That said, the font size was fine before the upgrade with this panel height. When I do an apt-get update && apt-get upgrade && apt-get dist-upgrade I don't see any packages that haven't been updated. I will try creating a new user later today.
6th October 2016, 7:39
It's possible to use the resize handle if you do the screen edge handle before. So when you go into edit panel mode, first use the the screen edge handle and just move the panel to another screen edge and back to its original position. After this, the resize handle will work. Definitely a bug I think.
smoreau Offline
6th October 2016, 8:51
(6th October 2016, 7:39)rocky7x Wrote: It's possible to use the resize handle if you do the screen edge handle before. So when you go into edit panel mode, first use the the screen edge handle and just move the panel to another screen edge and back to its original position. After this, the resize handle will work. Definitely a bug I think.
I confirm this bug occuring since Plasma update.
SM
Pfiff Offline
6th October 2016, 16:52
Me too, I confirm this bug since the last update.
Ciao!
Dieter
  Apps icons on the panel won't get bigger evb0110 24 90,106 4th February 2018, 10:22
Last Post: evb0110
  Maui update program 2 wiped out plasma 5 and all programs ali_deda 18 69,271 2nd February 2018, 21:48
  How to reset KDE Plasma and desktop to Maui 17.03 default? RealPTR 2 14,587 11th December 2017, 13:53
Current time: 14th September 2026, 16:04 Powered By MyBB, © 2002-2026 MyBB Group.
