Maui Forums › Maui Support › Plasma Desktop › [Closed] - KWallet breaks with a simple logout/in.
Pages ({1}): 1 2 3 4 Next »
Question  15th October 2016, 9:22 (This post was last modified: 1st January 2017, 4:39 by kdemeoz.)
As per my earlier https://forums.mauilinux.org/showthread....1#pid39551;
"...for me in 5.8.0 logouts are still no good compared to reboots, because sadly with a simple logout/in, KWallet breaks... it will not accept my password, hence all the programs relying on KWallet to supply their own passwords, fail. This is not a new fault, it's been this way since my 5.8.0 upgrade, but i forgot to..." ... create a dedicated thread for it, til now [coz the bug continues, & it's pretty annoying]. Everything is good again after a full reboot, but that is extremely disruptive. I would like KWallet to behave itself when i log out & in again, without having to instead reboot.
15th October 2016, 10:00
I guess maybe it isn't killed on logout (or closed).
That might be the root issue. I wonder just out of curiosity if you enter a tty terminal and login there (Ctrl+Alt+F1 for tty and Ctrl+Alt+F7 to go back on the graphical user interface) and execute a restart of the login manager (which restarts X basically and should close the wallet for good) helps.
You can restart it with the command sudo systemctl restart sddm
16th October 2016, 9:34
Thanks, but still no good. Ctrl+Alt+F1 did not produce tty, just a blank screen, though Ctrl+Alt+F7 did bring me back to my graphical session ok. Then whilst in the session, in Konsole i ran sudo systemctl restart sddm. As expected this did take me back to a new login screen, BUT... after logging in to the clean new session, KWallet was STILL broken / closed, & still rejected my password when i began using pgms whose credentials are stored in KWallet [it shouldn't even pop-up to ask me for password, as it's supposed to get my password from the login process, just like successfully occurs after a full reboot].
After the sequence summarised above, i clicked the tray Network Manager icon, to activate my VPN. Instead of doing so, it threw up this, & rejected my password:
I then tried to access KWallet from the Applications Menu, but:
Bummer!!
PS -- I'll declare this, in case it's somehow relevant; my /home partition is encrypted, as per my original Ubiquity Installer setting [remember, we corresponded about this when i first began testing Maui, as your original installer in the ISO was faulty wrt encryption].
20th October 2016, 3:39
I needed, within the last 30', to logout/in, but exasperatingly this turned into yet another full reboot when, once again, after the logout/in kwallet was once again broken. Clearly this is an intractable problem, given the 100% failure rate i'm experiencing with it, & the erstwhile lack of notified solutions. Questions:
1. Is there likely to be a solution during the remaining life of Maui 1?
2. Has this been explicitly tested in Maui 2, & is it 100% reliable therein?
20th October 2016, 5:25
Did you enable Kwallet under the under the Plasma Services kcm as well as in the kwallet kcm?
I do believe that this may be causing your problem with this not sticking.
20th October 2016, 6:22
Thanks for your reply. Answer to both questions = Yes. Here's the pics [are any of my settings in either, wrong-looking to you?]:
20th October 2016, 7:28
Shouldn't one of those "close when" selections be activated, otherwise the wallet would be open all the time.
20th October 2016, 8:26
Oh? At the risk of sounding stupid, is it a bad thing for wallet to stay open when i'm using my pc? To experiment, i've now activated the 3rd option; "Close when last application stops using it".
Interestingly, after reading your latest reply, i checked the system tray, expecting to see wallet listed there [given it should have opened(???) last time i rebooted], & was most surprised to find it's not there [& i am still actively using my Vivaldi-Snapshot browser, & VPN, two of the pgms linked to my wallet]. Odd!
Logically, having made that setting change now [which TBH i can't see how will help the main problem of this thread], i should now retest via a logout/in. However, given my pessimistic expectation that it won't help, & that therefore post log-in when i run two of my things linked to kwallet [my VPN, & my browser], they'll get rejected [again] & i'll have to suffer the further disruption of yet another full reboot. I'll have to do this test another time...
22nd October 2016, 11:58
Well, as i expected, the recent kwallet setting change did nothing to fix this annoying bug.
Furthermore, since my last post the Plasma 5.8.2 upgrade has occurred, but very disappointingly i've found that i STILL cannot do a simple logout/in [due to the kwallet breakage that ensues], so still every time i need to do a quick logout/in [eg, after making some relatively trivial UI aesthetic change via Settings], i have to instead do the longer & more disruptive full reboot.
Pls, is there nothing that can be done to resolve this?
22nd October 2016, 22:23 (This post was last modified: 22nd October 2016, 22:25 by AJSlye.)
Could it posibly be that you have the seesion set to use an empty session at login?
Login & Logout settings:
On Login you may choose one of three options on what should happen when you log into KDE:
Restore previous session:
If this option is checked, KDE will save your current session's state when you logout. KDE will restore your session on the next login, so you can continue to work with a desktop just like you left it.
Restore manually saved session:
Instead of restoring KDE to the state it was when you logged out last, it will be restored to a specific state that you have saved manually.
If this option is checked, the start menu offers an additional item Leave → Save Session.
Start with an empty session:
If you choose this option, KDE will never restore sessions that it has saved.
Question [Closed, Unsolved] - Unexpected Group Change. kdemeoz 1 10,768 20th May 2017, 5:43
Question [Closed] - plasma-widget-volumewin7mixer [Tower] kdemeoz 3 18,795 18th March 2017, 9:07
Information [Closed] - Disable middle-button paste in plasma5 ? kdemeoz 5 27,634 12th January 2017, 1:44
Current time: 27th September 2026, 19:49 Powered By MyBB, © 2002-2026 MyBB Group.
